BH Series
Retrofit Battery Inverter I 3-6 kW I Single Phase I HV
STÁHNOUT PDF >>
Posunout
Fanless & quiet
Elegant & compact
The GoodWe BH Series inverter is a single-phase, AC-coupled retrofit inverter compatible with a wide range of high voltage batteries from 85V to 460V. It is designed to maximize self-consumption with a UPS-level switching backup function. The pre-wired communication cables and AC connector’s Plug & Play simplify installation, operation, and maintenance.
<10 ms UPS-level switching
IP65 ingress protection
Quality and robust components
Fanless & quiet
Elegant & compact
Optimised Energy Autonomy
High backup output power with overload capability. Wide battery voltage range (85-460V) supports various battery capacities and power.
Compatible with multiple battery brands
Highest Safety Standards
Metal aluminium houseing with IP65 protects the inverter and makes it possible to install it both inside and outside.
High quality components
GW3K-BH
85~400
Max. Charging Current(A)
32/32
Max. Discharging Current (A)
230
3000/3300 (CEI 0-21)
Protection Degree
3000
GW3600-BH
85~460
25/25
230
3600/3960 (CEI 0-21)
Protection Degree
3600
GW5000-BH
85~460
25/25
230
5000/5500 (CEI 0-21)
Protection Degree
GW6000-BH
85~460
25/25
230
6000/6600 (CEI 0-21)
Protection Degree
6000
