2019-11-18
Compact and Powerful: GoodWe ET Series Delivers Independence and Non-Stop Energy
Compact and Powerful: GoodWe ET Series Delivers Independence and Non-Stop Energy-Novinky
 GoodWe ET Series
Covering a power range of 5 kW, 8 kW and 10 kW, the ET Series allows 30% DC oversizing to fully maximize yield during extreme hot and cold weather and features a wide battery voltage range of 180 – 550 V to ensure customers flexibility choices and compatibility with different type of lithium battery. Furthermore, it features Uninterruptible Power Supply (UPS) to inductive loads such as air conditioners or refrigerators with an automatic switchover time of less than 10 milliseconds, providing grid-tied savings when the grid is up and off-grid independence and security when it is down or compromised.
GoodWe ET Series
Besides, new GoodWe ET series storage inverter manufactured to be very compact with dimension size of 415*516*160 mm and lightweight (25kg) makes it easier for installation and maintenance both indoors and outdoors. Thanks to its cooling technology design using natural convection, the inverter runs reliably with quiet operation(<30dB) and a long-life span. It also equips with AC charging function whereas alternative current able to charge the battery even though the inverter did not meet its maximum performance.
The brand new GoodWe ET Series is a three-phase high voltage energy storage inverter that enables enhanced energy independence and maximizes self-consumption through export limit feature and time of use shifts for reduced electric bills.
