2019-11-18
GoodWe’s Accelerator to Grid Parity - Versatile 80kW String Inverters
GoodWe’s Accelerator to Grid Parity - Versatile 80kW String Inverters-Novinky
Furthermore, GoodWe engineers realize the integrated design based on performance and reliability of mechanical component. These two inverters surprise people with their adaptability to extreme climates. They can withstand a wide range of temperatures from -30℃ to 60℃, go 4000 meters above sea level and its biggest standout fact is capability to operate at full load at 50 degree Celsius. With a completely waterproof solid casing made from aluminum-magnesium alloy in addition to an IP65 protection grade, the new MT inverters are able to adapt to any kind of climate. A smart fan with the highest IP68 protection grade allows strong heat dissipation and ensures a long product lifespan. Most importantly, the DC bus capacitors assembled inside the equipment are all film capacitors that lasts three times longer than electrolytic capacitors. The output filters capacitor uses capacitors with sustainable and reliable operational standards at 85℃ and 85% humidity.
